Aggiornamento: X-Stellarium Go to page << >> |
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | X-Stellarium 0.14.3 Link winPenPack -Link- Aggiornamento dalla versione 0.14.2 alla 0.14.3 Home: -Link- Direct link 32 bit not portable (classic version): -Link- Direct link 64 bit not portable: -Link- Stellarium User Guide (ver. 0.12.3.1): -Link- Stellarium at Sourceforge: -Link- What's new: -Link- b.t.w. stellarium-0.14.3-classic-win32.exe: -> Stellarium 0.14.3 for Windows (32-bit; Windows XP) based on Qt 5.5.1 (MinGW GCC 4.9.2; OpenGL) with audio support. -> This is classic Windows application with support 3rd-party plugins. | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Stellarium 0.15.1 Link winPenPack Aggiornamento dalla versione 0.14.3 alla 0.15.1 Home: -Link- Direct link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Stellarium 0.15.2 Link winPenPack Aggiornamento dalla versione 0.15.1 alla 0.15.2 Home: -Link- Direct link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Stellarium 0.16.0 Link winPenPack Aggiornamento dalla versione 0.15.2 alla 0.16.0 Home: -Link- Direct link: -Link- | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1737 | X-Stellarium 0.19.3 Link winPenPack Aggiornamento dalla versione 0.16.0 alla 0.19.3 Home: -Link- Direct link: -Link- | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1737 | X-Stellarium 0.20.0.1 Link winPenPack Aggiornamento dalla versione 0.19.3 alla 0.20.0.1 Home: -Link- Direct link 32 bit : -Link- Direct link 64 bit: -Link- | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1737 | X-Stellarium 0.20.4 Link winPenPack Aggiornamento dalla versione 0.20.0.1 alla 0.20.4 Home: -Link- Direct link 32 bit : -Link- Direct link 64 bit: -Link- | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1737 | X-Stellarium 0.21.0 Link winPenPack Aggiornamento dalla versione 0.20.4 alla 0.21.0 Home: -Link- Direct link 32 bit : -Link- (0.20.4) Direct link 64 bit: -Link- Avvertenza: da questo numero di rilascio la versione per Windows è solo a 64 bit. Chi volesse usare quella a 32 bit deve scaricare la precedente versione 0.20.4 [ Edited Tue 30 Mar 2021 - 10:11 ] | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1737 | X-Stellarium 0.21.2 Link winPenPack Aggiornamento dalla versione 0.21.0 alla 0.21.2 Home: -Link- Direct link 32 bit : -Link- Direct link 64 bit: -Link- Nota: mi sa che devono aver avuto un bel po' di proteste per far tornare disponibile anche la versione a 32 bit. In ogni caso, meglio così. | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1737 | X-Stellarium 0.21.3 Link winPenPack Aggiornamento dalla versione 0.21.2 alla 0.21.3 Home: -Link- Direct link 32 bit : -Link- Direct link 64 bit: -Link- | ||
