Aggiornamento: [librerie] Java SE Runtime Environment Go to page << >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Java SE Runtime Environment 8 Update 91 Link winPenPack Aggiornamento dalla versione 8 Update 77 alla 8 Update 91 Home: -Link- Direct link (32 bit): -Link- Direct link (64 bit): -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Java SE Runtime Environment 8 Update 101 Link winPenPack Aggiornamento dalla versione 8 Update 91 alla 8 Update 101 Home: -Link- Direct link (32 bit): -Link- Direct link (64 bit): -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Java SE Runtime Environment 8 Update 121 Link winPenPack Aggiornamento dalla versione 8 Update 111 alla 8 Update 121 Home: -Link- Direct link (32 bit): -Link- Direct link (64 bit): -Link- [ Edited Wed 18 Jan 2017 - 20:39 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Java SE Runtime Environment 8 Update 131 Link winPenPack Aggiornamento dalla versione 8 Update 121 alla 8 Update 131 Home: -Link- Direct link (32 bit): -Link- Direct link (64 bit): -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Java SE Runtime Environment 8 Update 141 Link winPenPack Aggiornamento dalla versione 8 Update 131 alla 8 Update 141 Home: -Link- Direct link (32 bit): -Link- Direct link (64 bit): -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Java SE Runtime Environment 8 Update 144 Link winPenPack Aggiornamento dalla versione 8 Update 141 alla 8 Update 144 Home: -Link- Direct link (32 bit): -Link- Direct link (64 bit): -Link- | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | Java SE Runtime Environment 8 Update 281 Link winPenPack -Link- Aggiornamento dalla versione 8 Update 144 alla 8 Update 281 Home: -Link- Direct link (32 bit) not portable: -Link- Direct link (64 bit) not portable: -Link- Java JRE for Windows: Java JRE for Windows released on January 19, 2021 Softpedia: -Link- Nota Java è richiesta da programmi come X-LibreOffice. Non so se il programma JavaGet -Link- scarica automaticamente l'ultima versione stabile. | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | Java SE Runtime Environment 8 Update 351 Link winPenPack -Link- Aggiornamento dalla versione 8 Update 281 alla 8 Update 351 web site: -Link- Download page: -Link- Direct download (32 bit) not portable: -Link- Direct download (64 bit) not portable: -Link- Release date: October 18, 2022 Softpedia: -Link- Come aggiornare JRE su X-LibreOffice: Per aggiornare Jave RE su X-LibreOffice: -> guardate dentro la cartella \Lib (che contiene le librerie) dovreste vedere le sottocartelle: --> 7za --> Fonts --> Java cancellate senza indugio la sottocartella Java ed avviate X-LibreOffice. Il launcher vi avviserà che le librerie Java sono mancanti e si offrirà di scaricarle (l'ultima versione): rispondete SI e il launcher farà il lavoro per voi. Ho notato che ad ogni release di Jave SE Runtime Environment, X-LibreOffice si avvia più velocemente: ciò è sicuramente dovuto al codice più ottimizzato presente nelle nuove versioni delle librerie. | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | Java SE Runtime Environment 8 Update 361 Link winPenPack -Link- Aggiornamento dalla versione 8 Update 351 alla 8 Update 361 web site: -Link- Download page: -Link- Direct download (32 bit) exe installer: jre-8u361-windows-i586.exe Direct download (64 bit) exe installer: jre-8u361-windows-x64.exe GitHub project 'java_download.sh': -Link- Direct download (32 bit) portable: jre-8u361-windows-i586.tar.gz Direct download (64 bit) portable: jre-8u361-windows-x64.tar.gz Release date: January 17, 2023 Softpedia: -Link- Come aggiornare JRE su X-LibreOffice: Per aggiornare Jave RE su X-LibreOffice: -> guardate dentro la cartella \Lib (che contiene le librerie) dovreste vedere le sottocartelle: --> 7za --> Fonts --> Java cancellate senza indugio la sottocartella Java ed avviate X-LibreOffice. Il launcher vi avviserà che le librerie Java sono mancanti e si offrirà di scaricarle (l'ultima versione): rispondete SI e il launcher farà il lavoro per voi. Ho notato che ad ogni release di Jave SE Runtime Environment, X-LibreOffice si avvia più velocemente: ciò è sicuramente dovuto al codice più ottimizzato presente nelle nuove versioni delle librerie. Nota su versioni portatili (tarball): sulla pagina del progetto 'java_download.sh' cercare i post dell'utente Nadwey [ Edited Fri 27 Jan 2023 - 16:16 ] | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1737 | Java SE Runtime Environment 8 Update 371 Link winPenPack -Link- Aggiornamento dalla versione 8 Update 361 alla 8 Update 371 web site: -Link- Download page: -Link- Direct download (32 bit) exe installer: jre-8u371-windows-i586.exe Direct download (64 bit) exe installer: jre-8u371-windows-x64.exe GitHub project 'java_download.sh': -Link- Direct download (32 bit) portable: jre-8u371-windows-i586.tar.gz Direct download (64 bit) portable: jre-8u371-windows-x64.tar.gz Release date: April, 18 2023 Softpedia: -Link- Come aggiornare JRE su X-LibreOffice: Per aggiornare Jave RE su X-LibreOffice: -> guardate dentro la cartella \Lib (che contiene le librerie) dovreste vedere le sottocartelle: --> 7za --> Fonts --> Java cancellate senza indugio la sottocartella Java ed avviate X-LibreOffice. Il launcher vi avviserà che le librerie Java sono mancanti e si offrirà di scaricarle (l'ultima versione): rispondete SI e il launcher farà il lavoro per voi. Ho notato che ad ogni release di Jave SE Runtime Environment, X-LibreOffice si avvia più velocemente: ciò è sicuramente dovuto al codice più ottimizzato presente nelle nuove versioni delle librerie. Nota su versioni portatili (tarball): sulla pagina del progetto 'java_download.sh' cercare i post dell'utente Nadwey | ||
