Aggiornamento: [librerie] Java SE Runtime Environment Go to page << |
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | eagleman wrote ... Java SE Runtime Environment 8 Update 371 Link winPenPack -Link- Aggiornamento dalla versione 8 Update 361 alla 8 Update 371 I links per il download di Java SE Runtime Environment sono tutti sbagliati. I links corretti sono: web site: -Link- Download page: -Link- Direct download (32 bit) exe installer: jre-8u371-windows-i586.exe Direct download (64 bit) exe installer: jre-8u371-windows-x64.exe GitHub project 'java_download.sh': -Link- Direct download (32 bit) portable: jre-8u371-windows-i586.tar.gz Direct download (64 bit) portable: jre-8u371-windows-x64.tar.gz Release date: April 18, 2023 Softpedia: -Link- Il resto delle note va bene. | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3358 | scheda sistemata. Grazie! | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | Taf wrote ... scheda sistemata. Grazie! grazie a te. | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1737 | Java SE Runtime Environment 8 Update 381 Link winPenPack -Link- Aggiornamento dalla versione 8 Update 371 alla 8 Update 381 web site: -Link- Download page: -Link- Direct download (32 bit) exe installer Direct download (64 bit) exe installer Release date: July 18, 2023 [ Edited Thu 20 Jul 2023 - 08:25 ] | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | Java SE Runtime Environment 8 Update 381 Link winPenPack -Link- Aggiornamento dalla versione 8 Update 371 alla 8 Update 381 web site: -Link- Download page: -Link- Direct download (32 bit) portable: jre-8u381-windows-i586.tar.gz Direct download (64 bit) portable: jre-8u381-windows-i586.tar.gz Release date: July 18, 2023 | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | Java SE Runtime Environment 8 Update 391 Link winPenPack -Link- Aggiornamento dalla versione 8 Update 381 alla 8 Update 391 web site: -Link- Download page: -Link- Direct download (32 bit) Installer: jre-8u391-windows-i586.exe Direct download (64 bit) Installer: jre-8u391-windows-x64.exe Direct download (32 bit) Portable: jre-8u391-windows-i586.tar.gz Direct download (64 bit) Portable: jre-8u391-windows-x64.tar.gz Release date: October 17, 2023 Nota per gli utilizzatori di X-LibreOffice: 1. Rinominate la cartella 'jre1.8.0_381' in ''jre1.8.0_391'' (si trova dentro \Lib\Java) 2. cancellate il contenuto della cartella 'jre1.8.0_391' appena rinominata 3. scompattare la versione Portable (32 oppure 64 bit) all'interno di detta cartella 4. avviate LibreOffice, poi --> Strumenti --> Opzioni --> Avanzate --> cercate la cartella 'jre1.8.0_391' e confermate con OK 5. chiudete e poi riavviate X-LibreOffice | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | Java SE Runtime Environment 8 Update 401 Link winPenPack -Link- Aggiornamento dalla versione 8 Update 391 alla 8 Update 401 web site: -Link- Download page: -Link- Direct download (32 bit) Portable: jre-8u401-windows-i586.tar.gz Direct download (64 bit) Portable: jre-8u401-windows-x64.tar.gz Release date: January 16, 2024 | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1737 | Java SE Runtime Environment 8 Update 411 Link winPenPack -Link- Aggiornamento dalla versione 8 Update 401 alla 8 Update 411 web site: -Link- Download page: -Link- Release date: April 16, 2024 | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | Java SE Runtime Environment 8 Update 411 Portable Link winPenPack -Link- Aggiornamento dalla versione 8 Update 401 alla 8 Update 411 web site: -Link- Download page: -Link- Direct download (32 bit) Portable: jre-8u411-windows-i586.tar.gz Direct download (64 bit) Portable: jre-8u411windows-x64.tar.gz Release date: April 16, 2024 | ||
Go to page <<
