Aggiornamento: Q-Dir Go to page << >> |
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3358 | Q-Dir 4.57 Link winPenPack Aggiornamento dalla versione 4.56 alla 4.57 Home: -Link- Direct link: -Link- Direct link UNICODE: -Link- Direct link 64bit: -Link- Risultato test: niente da segnalare [ Edited Fri 27 May 2011 - 16:02 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Q-Dir 4.58 Link winPenPack Aggiornamento dalla versione 4.57 alla 4.58 Home: -Link- Direct link: -Link- Direct link UNICODE: -Link- Direct link 64bit: -Link- Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Q-Dir 4.59 Link winPenPack Aggiornamento dalla versione 4.58 alla 4.59 Home: -Link- Direct link: -Link- Direct link UNICODE: -Link- Direct link 64bit: -Link- Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Q-Dir 4.61 Link winPenPack Aggiornamento dalla versione 4.59 alla 4.61 Home: -Link- Direct link: -Link- Direct link UNICODE: -Link- Direct link 64bit: -Link- Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Q-Dir 4.62 Link winPenPack Aggiornamento dalla versione 4.61 alla 4.62 Home: -Link- Direct link: -Link- Direct link UNICODE: -Link- Direct link 64bit: -Link- Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Q-Dir 4.64 Link winPenPack Aggiornamento dalla versione 4.62 alla 4.64 Home: -Link- Direct link: -Link- Direct link UNICODE: -Link- Direct link 64bit: -Link- Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Q-Dir 4.66 Link winPenPack Aggiornamento dalla versione 4.64 alla 4.66 Home: -Link- Direct link: -Link- Direct link UNICODE: -Link- Direct link 64bit: -Link- Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Q-Dir 4.67 Link winPenPack Aggiornamento dalla versione 4.66 alla 4.67 Home: -Link- Direct link: -Link- Direct link UNICODE: -Link- Direct link 64bit: -Link- Risultato test: niente da segnalare | ||
sceicco |
Registered Member #5022 Joined: Tue 05 Jun 2007 - 08:51Posts: 385 | Q-Dir 4.69 Link winPenPack Aggiornamento dalla versione 4.67 alla 4.69 Home: -Link- Direct Link: -Link- --- edit zandet2 --- niente da segnalare Nota: sul sito non sono presenti versioni storiche del programma, quindi ad ogni aggiornamento la nostra scheda punta direttamente all'ultima versione rilasciata [ Edited Fri 12 Aug 2011 - 09:28 ] | ||
